what kinda hp would i be looking at
tyler
74
canada
what do you guys make with setups close to this
24x12x3 intercooler and 3 inch piping
3 inch y-pipe
supra mkiv 550's
safc neo
aem wideband
256 cams
3 inch intake
3 inch exhaust
hks fcd
turbosmart ebc
at 14-18 psi
also what is optimal afr
Thanks Tyler
JASONA70
nomnomnom
Oct 27, 2006
743
socal
3 inch y-pipe
supra mkiv 550's
safc neo
aem wideband
256 cams
3 inch intake
3 inch exhaust
hks fcd
turbosmart ebc
at 14-18 psi
Thanks Tyler
"at 14-18 psi"
with stock twins !?!?! and CERAMIC turbine?!
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
14-18 isn't that big of a deal
i mean hell i just put a 3 inch exhaust on my car and its running 15 psi on its own.....can't stop it when its cool out side
OneJoeZee
Retired Post Whore
aboard the Argama
Don't buy into the bullshit, guys. Your turbos are not going to destroy themselves just because you were running at 14-18psi.
tyler
74
canada
i dont care if i blow my stock twins.. i mean its bound to happen eventually.. just more motivation to go single when it happens:)
Ric
Setting the standard
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
I ran my turbos at 18psi for along time. They never blew.
On your setup Tyler, your going to run VERY VERY VERY rich.
Stock 380cc's or JDM 440's would be better.
If your lucky, maybe 340whp very tuned.
Ric
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
if your going to install 550's and minus out 33% so the car runs good.. why even install 550's? That just puts you back to 380cc's of fuel.
My 1JZ ran rich at 18psi with stock injectors. 10:1
tissimo
Stock is boring :(
Melbourne, FL
stock injectors seem to run out of fuel ~ 350-360 whp.. hell be on the edge of that.. just keep an eye on it, but it probably wouldn't hurt to upgrade..
The Reaper
Jan 10, 2006
1,909
Florida
not only that but tuning it will net more power too
im on stock everything with an exhaust and intake and it STILL needs to be tuned so it can't hurt to have an SAFC
tyler
74
canada
the reason for the 550's is because i plan on getting rid of the twins once i blow them and have bigger goals after that:)
Tyler
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
so just change the injectors then, in case your plans change in between then and now:)
or did i forget that you already have the 550's
i am basicly stock and my next plan is to see where the fuel is at. with a SAFC and a wideband so i can read the AFR's
The Reaper
Jan 10, 2006
1,909
Florida
bobiseverywhere said:
just to elaborate all i have is a DP and 3" Exhaust no Cat and a Mushroom HKS Filter.
i have seen my Turbos boost just with that between 0.8 and 0.9 bar
i have just a filter and 3 inch exhaust from the stock y-pipe back and i've had it hit 17.3 PSI on a cold night in 3rd gear going up an on-ramp. mad fuel cut but for some reason it waited til 17.3 psi.
now with the e-01 it stay around .9 bar
