What is the rotor thing on the passenger side cam?
Turbo Targa
115
Ok I dont have a camera available right now, but just out of curiousity was is the thing that plug into the passenger side of the head, and has a rotor that meshes with the cam? What does it need to be set at? I noticed its slightly ajustable.
Thanks!
Alex
CPT Furious
Now MAJ FURY!
KDOV
With Te1 and E1 connected in the diagnostic port, yes. With them disconnected, it should be over 12 degrees if memory serves.
CPT Furious
Now MAJ FURY!
KDOV
Well, you set the base timing with the diagnostic port and then you unplug it to check to make sure it jumps 12 or above, IIRC...
