what is ra value?
bowtiebuba
stangs hate supras
Sep 1, 2005
207
marion iowa
what is ra value, i dont know weater to get comitec or titan, i was reading something on ra value, but dont know what it is what head gasket should i go with
Turkish
188
RA value is a roughness standard. In other words how smooth the surface in your case the head needs to be in order to properly install said head gasket.
TONY!
Habitual Supra Killer
Tonyland
Roughness Average
The lower the number, the smoother the surface -- many think of it the other way around (it is not like sand paper).
stratoayu
435
surrey
haha i was going to say roughness average, but i didnt wanna get flamed and say i was wrong :D but good to know that i was right at least... looks like ill graba cometic when i do a mhg...
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Cometic and a set of ARPs are great! On my last Supra I buitl, I went with a Cometic 1.3mm mhg and ARP head bolts torqued to 78 pounds... I went with Cometic because they had the most lenient ra, and they have a really good reputation... Not to mention that Luis is running 40 pounds of boost on a cometic mhg... So I fealt comfortable with them... Also, I wasnt planning on pulling my motor to lap the block, so I needed a forgiving gasket...
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
It's a multi layered metal head gasket... The rivets hold all three layers together... SOME of their mhg's you have to remove a rivet, mine didnt need that... All you have to do is place the mhg on your block,a nd make sure that when the head sets down, it doesnt crush a rivet... If it is going to hit one, then punch it out...
stratoayu
435
surrey
so is there any way to measure an ra value ? cuz it would be nice to know if im going to need to pull the block or not...
bluemax
The Family Man
Orange County, CA
Surface roughness is accurately measured using a machine. Most good machine shops will have one.
There are comparison panels too, but they're used for estimating surface roughness.
