What is EVO?
JMDigital
Authorized Vendor
Jun 2, 2006
976
Tampa, Florida
Ok my power steering fluid is leaking. I found out today that is is the Rack&pinion that is leaking and I need to replace it. When ordering the part I was asked if it has EVO or not. I dont know what that is ?
Thanks for the help.. Oh my the way I am told the part is $400.00 and its a 5week special order... can you let me know if I am getting shafted :1zhelp:
GotBoost?
I do
Nov 25, 2005
318
By My Computer
Your power steering fluid is leaking from where: high pressure PS hose, the bellows, pump, etc? It's very possible the PS rack costs $400. More or less, depending on what store is ordering your part. If $400 includes the part and installation, that's a fair price. Btw, if the PS rack is leaking, it usually loses all its fluid in a matter of seconds, fyi.
The high pressure hose doesn't even cost $100, plus install. It goes bad from heat, pressure and age. When the high pressure goes bad, the system loses oil much more slowly.
I don't know what they're calling EVO, but some Supras have variable effort PS systems. Maybe that's what they're talking about.
SupraDerk
The Backseat Flyer
Sep 17, 2005
546
Tallahassee
Nooooooooot true. My rack leaked and it took a full day for the fluid to completely leak out.
The 89+ I guess had an option, not sure if it was standard or not. They had PPS (progressive power steering) which used a PPS ECU to "dumb" the rack down at higher speeds. That might be what EVO is.
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
I have an 89 and I have thought it had speed sensitive steering but wasn't for sure...I didn't notice it until I got my speedo fixed and it steering felt completely different afterwards.
mkIIIman089
Ohio
^ ah hah, maybe thats what that speed signal off the speedo is used for! I've been trying to figure it out for a while now.
JMDigital
Authorized Vendor
Jun 2, 2006
976
Tampa, Florida
Arg.. so I need to put fixing the spedo a little higher on the list.. It seems it does alot more then tell me to slow down..
I dont know exactly where its leaking from but the mechanic is a friend and I trust him.
GotBoost?
I do
Nov 25, 2005
318
By My Computer
SupraDerk said:
Nooooooooot true. My rack leaked and it took a full day for the fluid to completely leak out. QUOTE]
When my rack was leaking, it would loose all its fluid in about 200 yards. Yeah, that's a massive leak. I guess it depends on where the leak is at.
mkIIIman089
Ohio
jetjock said:
It's used for a lot of things Colin. The ISC system uses it, it's used to calculate deceleration fuel cut off and resumption, cruise control, TEMS, ECT functions and more. Driving around with no speed sensor input effects a lot, especially regarding EFI operation.
Thats pretty interesting. I was always under the impression that most of that stuff was calculated simply by RPMs... Thanks!
supra90turbo
shaeff is FTMFW!
32
MA, 01440
EVO actuator is GM's term for PPS.
All pumps I have ever ordered for customers that have variable assist or whatever gm likes to call it has specified "Must transfer original EVO actuator to new pump"
