What if I unplug the Map sensor from the manifold? will that get rid of feul cut? The reason i think you might be able to is because i ran a turbo motor/ecu harness in a non-turbo body/body harness and it ran fine without a map senor. I do believe it is only for the stock boost gauge. Also on a mr2 there is a resistor at radio shack you can by that will get rid of fuel cut. I know its not the "best" or "most reliable" way to get rid of it, but i dont have $100+ for a FCD.
