Say I put a newer N/A motor 30-50K in my turbo car and swaped the intake manifold, exhaust manifold and put the turbo on that motor? The higher compression and the N/A cams would add a good deal of power, probably in the range of about 40 HP? In my opinion Toyota plays it safe with the low compression pistons but I think they go too far. Stock boost is about 6 PSI, I can run 20 and still no det so I would imagine with N/A compression I could get away with the turbo on high octain as long as I dident go crazy on the boost. Also N/A motors with low miles go for half the price of used turbo motors!!!! What do you guys think?? I think it could work...
