What I did today!
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
Here's what I did today.
I built and installed my laptop mount. It is on a Flex Arm that is bolted to the mounting rail under the passenger seat. When I don't want the laptop there, I simply remove it and bend the flex arm to lay flat on the floor.
It's sturdy, completely adjustable, and is passenger friendly!
CajunKenny
Nov 15, 2007
3,255
Washington
Thanks guys!
It will actually pull in quite a bit closer to the driver's seat than what you see in the pic.
Carter: I can take pics of the individual pieces for you. And how it's mounted.
I don't have part numbers and such... Some of the parts were custom fab'd by me so I know they're not anywhere! ;)
The Flex Arm that I chose to use is just about maxed out by my Dell Mini 9. It won't support anything larger. So it's limited in that sense...
Turbo Habanero
4,229
Tucson,AZ
Thats awesome now you can go so fast when you laptop is beeping say shut up!!! and watch your floor boards drop. LOL nice setup man
92nsx
2,957
Clearwater, MN
:) nice, It looks almost identical to one I made for my last Caddy 3 years ago. The only problem was that my "flex arm" couldn't hold the weight of my laptop long. After a few bumps in the road it would fall over. I used plexiglas (sp?) and Velcro to hold the laptop. What are you using?
CajunKenny
Nov 15, 2007
3,255
Washington
Each end of the flex arm has threaded studs sticking out. One end of the flex arm is mounted to a bolt at the bottom of my sparco seat via a bracket that I cut out of 1/8" Aluminum Stock.
The other end screws into a 360* Ball Mount that has been drilled and tapped accordingly.
The Ball Mount attaches to a 4x5.5" Aluminum Plate. The plate has velcro on it.
The key part to this type of setup is the arm. Without a strong one. FAIL! ;)
