What have you damaged?
SySt
Burnsville, Minnesota
List what you guys have damaged while driving your Supras. A little story about each would be good too.
Here is my list.
Damaged 1: Bent right rear "toe" control arm, took a chunk out of right rear wheel and both rear tires, cracked rear bumper cover, clipped right rear brake line and scrapped up underside.
Story 1: I was driving home from my girlfriend's house around midnight on a saturday after a day of rain. I reached some curves I usually took really fast when it's dry. I am going about 65mph (when it's dry I can take this particular turn at around 110mph). I decided I wanted to slide around being it would be easy wet. I turn a little more sharply coming into the turn, simultaniously hitting the gas all the way down. Once the turbo kicks in I start getting more angle than I wanted due to heavy wheel spin. I let off and countersteer to correct it. I put too much countersteer in (full lock). My Supra now snaps the opposite direction, I frantically counter the other direction full lock and slam the brakes. That last move sends me into a 180 and I am now watching through a side mirror as I fly backward towards a curb. I hop the curb and hit a sign with my rear, I then do another 180 and come to a stop. I drive off the curb and realize my rear end is messed up (right rear had 5+ degrees of toe due to the control arm bending).
Damage 2: Blew HG.
Story 2: I had just installed my GReddy IC kit and put in a new water pump and thermostat housing gasket. I started up the engine and it stumbled due to improper ignition timing (had the CPS out). I needed to get to work and figured it would be ok for a day given the 7M has two knock sensors. I start driving and it feels like crap. I come up to an intersection that goes from two lanes to one. The guy next to me thought he'd get ahead of me, I thought otherwise. I punch the throttle through 1st, do a hard shift into 2nd and look in my mirror to see only a very thick cloud of white smoke, nothing else. I pull over and my engine is stumbling bad. I shut it down and pop the hood to have a look and coolant is all over the place. I try to start it and the starter engages but does not turn the motor over. I beleive I had so much coolant in the #4 cylinder that it was hydrolocking the engine.
Damage 3: Windshield shattered/cracked, cracked front bumper cover and dented hood.
Story 3: I was driving home from the races the first night I hung back out with my ex. I was in a mood to show off. I come around a corner doing about 55mph in 4th. I drop down to 2nd harshly and slam the gas. I get a lot of angle and save it perfectly. I keep driving towards home when it comes time to get on a clover leaf. I drop down to third and get to about 80mph and then start braking harshly from the clover leaf. I miscalculated the braking zone and my front wheels locked up just as I was about to let off and turn. I fly off the clover leaf and hit a sign mid-air. The sign flys out of the ground, bounces off my hood and shatters/cracks my windshield. The sign actually came about 4 inches from my face. I drive away as quickly as possible and head out on my way.
Damage 4: Shift fork
Story 4: I am picking up my girlfriend from work. I take off out of the parking lot hard through first and begin a hard shift into second only to have it not engage. At first I thought I missed second. I quickly realized my shift fork was broken as I had nothing but 3rd on up.
Kai
That Limey Bastard
Had some bastard drive into me the other day - bent the door :/
Blown a Coolant hose at the back of the block, causing instant steam!
Faulty Bulb Failure Module caused by water leaking into the Boot.
Driveshaft - Under investigation....
Neodeuccio
Addicted to boost...
Sep 30, 2006
846
Schenectady NY
So far I haven't really done much damage to my baby other than to the tires and clutch :evil2:
But the first day... I'll never forget that. The car was delivered to me by the previous owner on a Thursday evening about 3 months ago. The following day I went to the DMV, got plates, arranged insurance, and got her ready. So Saturday morning was the first day she was really on the road.
Now, I was leaving the house at the same time as my mother, though we were headed different directions, and in different cars. I had her 4 door Tracker parked in, so we hopped in our respective cars and prepped to go. Only I took a minute to set up my Ipod first. After getting it plugged in, I look up, and my mother's brake lights turn off as she starts backing toward me. We don't have a very big driveway, so there were only about 2 feet between us to start with, and that gets real small real fast. It took me like 5 years to afford and find a turbo Mk3, so I panic at the thought of my mother backing into it with her 4WD hitched mini-SUV before I've even taken her out of the driveway. I pound on the horn and start yelling my head off just in time. She stops after just barely touching me. I'm freaked, she's fretting, and I go to survey the damage...
The only thing that happened was the temp plate I was given until my custom one arrived was bent slightly where the tow hitch hit it. It never cost me a dime, but I'll never forget it.
Toyota h8r
Formerly KILLERMK3
Jan 24, 2006
187
Sylvania ohio
Kai said:
Oooh - i forgot the clutch - i wore my N/A clutch down to the rivets :D
how about dropping the clutch and exploding the clutch disk?(burnout) My big thing ive done is while driving, coolant overflow line popped off and sprayed coolant on the motor. Now the dam car misses very badly and wont run right.
SySt
Heh, reminds me of when I first got my Turob Supra. It was my second Supra. I went to start it after leaving work one day. I pulled the park brake off and put the clutch in, turned the key and felt a thud. My Supra rolled into me bosses car. I just took off, no damage done.
Disced
Pie + NYQuil = FTW
Edmonds, Wa
LoL.
I used to deliver in my car and I accidently ran up onto a curb and stripped out both bolts which hold the pinion to the front subframe causing me to not be able to turn the car anymore.
Brewster
So it goes.
Apr 15, 2005
1,156
Morgantown, WV
I rearended a battleship. The battleship was totalled.
Actually I haven't driven the car enough to break anything that wasn't already a messed up.
gixxer750
2jzget comingsoon!
Mississippi
I have broken....
1 differential, 1 transmission, 1 driveshaft, 4 clutches, many many rear tires, 2 engines, 5 turbos(20 psi on a ct), one lower intake manifold(cracked???).... thats about all the parts I have actually broken.
All the stories to all these breaks start "I was at the track and"
mkiiSupraMan18
Needs a new username...
United States
Rear Coil springs... LSD... (All that mkII torque, lol) more interior parts than I want to recall... anything that has little tiny bolts that I tend to twist off... Thats about it for me.
