What happens to tems when drop springs are added?
808steeze
28
Hawaii
I know this topic has been talked about a lot, however this situation is a little different.
First question what happens to the tems when drop springs are put on tems shocks. Does it make the tems useless or does it make the drop spring with tems shocks better.
The reason I am asking this is, I want to buy a set of drop springs; however the person I bought this 87 supra turbo from installed non tems shocks in the back and left the tems shocks in the front.
Should I just throw the drop springs on and call it a day or should I change either the fronts or back?
any help much appreciated!
Nothing changes to the tems with springs. It's the shock dampening be adjusted.
Up to you weather you want to keep them or not. New tems shocks are more expensive than non.
