I pulle my rotors off today to check the thickness and scuff them up because they were squeeking. When I finished the ABS loght came on. Im confused I didnt touch the sender at all. Then, when I went to pull the coodes I got 25 and 26. In cygnus it says its runnin lean(25) and rich(26) How the hell can you run rich and lean at the same time? I done know if the abs system has its one set of codes or not but I do need your help to figure out whats going on.
