what flywheel on my supra?
JZA80RR
norway
i got a ma70 with a 2jzgte aristo swap,running a jza70 bellhousing and a R154
but i dont now what flywheel i got... (gonna replace the starter ring on the flywheel)
what is normal to use on these swaps ? 2jz/1jz or 7m flywheel ?
JonoTurbo
Going for broke
CT
You have a 1jz flywheel. The 7m one has the wrong bolt pattern for the crank, and the 2jz ones have the wrong bolt pattern for the pressure plate, among other things.
