What else should I get?
Justin
Speakers?
Spokane, Wa
I'm doing a complete rebuild on my engine... I've got a hg and arp studs on the way then I think I'm ready to built it and drop it! here is the list of misc stuff I need, are there any suggestions on anything else I shoudl pickup before i get started? any other hoses i should replace?
No. 3 timing belt gasket
All Fuel Crush washers
All Oil Crush washers
Oil return line - block gasket
Timing Belt
Alt Belt
P/S Belt
Cold Start Injector gasket
All Three injector gromets x 6
A new ISC hose, that goes over to the accordian hose
the little coolant hose that goes from the back of the head to the pipe that wraps around the block
CPS Cover
CPS Cover Gasket
the seal that's in the rear of the tranny where the drive shaft goes.
americanjebus
Mr. Evergreen
wa.
VALVE STEM SEALS.
all the damn vacuum hoses that go under the throttle body, just go ahead and buy the hose techniques kitl
Justin
Speakers?
Spokane, Wa
americanjebus said:
VALVE STEM SEALS.
Valve Stem Seals have already been replaced
I'm not running any vacuum hoses except FPR, BOV, Heater VSV and Cruise.
Thanks for the input, that's exatly what I'm looking for
