what else do i need? getting ready to turn the boost up a bit
fixitman04
fixer of all things !!
Sep 18, 2008
787
north dakota
ok guys, ive caught the bug.
im getting ready to start upgrading.
my plans are: (what i currently have but not installed)
lexus afm
suprasport elbow to match my 3" exaust
rx7 550 injectors
afpr
hardpipes/intercooler
walbro 255
hks crossover pipe
boost gauge
full tuneup, all coolant hoses, and replace those damn leaking valvecovers
can i run stock electronics if i stay below fuel cut?
anything im overlooking
i currently have a manual boost controller, a k$n air filter, stock(i think)ct26, stock(i think)7m with a newer hg and head. im not looking to get much more than say 450 hp, just want to wake it up a bit.
nothing has been installed yet, so it is a clean slate... and yes there will be a build thread when i start:icon_bigg
fixitman04
Sep 18, 2008
787
north dakota
i do not know what hg was installed, i do not plan on a teardown till next winter. il deal with that problem if/ when it occures.
by something to tune with what do you recommend? i dont really want to piggyback as i eventually plan on a standalone.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
He can tune to a certain extent using the AFPR. The Lexus / 550 combo will work for the now, but it'll run really rich. Don't expect good gas mileage until you get a proper system in there for tuning.
I'd suggest adding a wideband to that list.
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
To hit 350-400hp you will also need at least a 57-trim upgraded CT26, and an SAFC with tuning, and maybe a clutch to hold that power. I would limit it to 15psi and 350hp with careful tuning if you don't have a MHG. Get the MHG if you can afford it(which will require surfacing BOTH the head and block)
fixitman04
Sep 18, 2008
787
north dakota
the turbo will come later this summer, hopefully so will a standalone. so i should not run without some sort of tuning device? or can i stay below fuel cut till i can get the stanadlone setup?
as for the clutch... atm i am an auto. im working on a r154 and a good clutch setup, but i still need a few parts and my tranny hasnt been built yet.....later this spring for that.
i have a wideband , just not in this car.... so il add a second sensor to the list
