What else do I need for my R154 swap ?
whitemike
1,164
Winter Park, Florida, United States
OK, before I get hit with a bat for asking for help on a common subject, I just want to say I searched. I read every single relevant thread that came up, and can't find a definitive answer to the question: "EXACTLY what parts are needed for my 5spd swap?"
Here's what I have:
-R154 Tranny/bellhousing
-PP/Clutch disk/7M R154 Flywheel
-TOB
-Pedals (I have all 3 from a 5Spd car)
-Master cyl, Slave cyl, lines
-Driveshaft
What am I missing, anything? I do NOT want to get balls deep into this car, and realize I need to wait a week for something to be delivered. I read my A/T ECU will work on a manual tranny, but I need to bypass the neutral safety switch, is this true?
Thanks so much guys,
-Mike
iwannadie
981
gilbert, az
Here's what I have:
-TOB
-Mike
r154
Bell housing
87 7m Manual ECU
Clutch / Brake pedal
7mgte clutch kit, disc, pressure plate, pilot, throw out bearing
R154 clutch fork
Short speedo cable
Full Length SS clutch hose
Clutch Slave Cylinder OEM
Clutch Master Cylinder OEM
ARP 7m Flywheel Bolts
Pressure Plate Bolts
R154 Clutch Release Hub kit/washers OEM
Pilot Bearing OEM
Marlin crawler shifter socket bushings
OEM used Flywheel
Flywheel resurfaced
Upper and lower flywheel inspection pates
Trans driver side wing bracket
Bell housing to trans bolts
TRD shift knob
OEM bell housing bolts x4
Shaft masters 1 piece aluminum drive shaft
OEM Exhaust rubber hangers
Felpro exhaust header to downpipe gasket x2
Redline MT 90
clutch master cylinder to clutch pedal clevis pin, wave washer, clip
driveshaft to differential bolts, washers, nuts x4
Catalytic converter gasket x2
Clutch cover gasket, passenger and driver side
Plus other hardware that couldn't be reused or didn't exist already. Not all of what I replaced was needed but it's what I ended up doing.
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
you don't need to get all that separately, as most of it comes together, like the inspection covers, they usually come already on...
he's also letting you know you should replace some of the parts now that the tranny is out the car, instead of doing it later...
iwannadie
981
gilbert, az
My bell housing came bare actually so I had to buy them. Didn't mean to add any confusion I just thought my parts list might give you an idea of what you may need.
I ran into a Lot of random small stuff that slowed me down, mostly fasteners though. The stupid clevis pin kit for the clutch pedal was one of them. People think just because they have a clutch pedal from a parts car that they are good to go, you still need the fasteners. Then stuff like driveshaft bolts you should really replace as cheap insurance.
RazoE
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
Definitely. Just like with an engine swap, it's not just the engine that needs to be changed..
speaking of the clevis, mine's acting up and causing my damn clutch pedal to stick on my 92..:(
