What driveshaft for a R154 2jzgte MK3 SUPRA?
jdmk3
2jzmk3
Mar 28, 2006
78
Walnut, CA
:1zhelp: I have the aristo and the 7mge driveshaft. Im unsure which will fit if any. Do I need to custom one of them or should I just get an aftermarket 7mgte one? :1zhelp:
Satan
Tampa
If using the R154, you'll use the 7M/R154 driveshaft (assuming using the 1JZ JZA70 bellhousing).
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
yea just get a 1JZ bellhousing and flywheel and yur 154 will bolt right up then you just use a stock 7MGTE driveshaft
