what does your fuel system look like
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
i am in the middle of maken mine and have it all figured out and most of it bought
what i am runing is
a1000
100 mc aeromotive vavled fule filter
-10 lines
custom sump still in the works
high flow one way cheak vavle
lipp high flow fule rail
a1000 fule reg
855cc injectors
aeromotive fule pump controler
i have great plan on how i am going to run this but hows your shat ran mabye give me an idea
see i cna pick 2 places for my pump not sure whitch place i going to monte it
Dec 3, 2003
6,653
Canada
Here are links that I came up with within a few mins. A picture of the mounting location and some info yet again.
There is only one really good place for this pump and we have been over this before. First link, post #5
http://www.supramania.com/forums/showthread.php?t=37501&highlight=fuel+pump+mounting+ideas
http://www.supramania.com/forums/showthread.php?t=56548&highlight=fuel+pump+mounting
http://www.supramania.com/forums/showthread.php?t=40925&highlight=fuel+pump+mounting
You do not need to upgrade the rail with your mods unless you like the idea of having to say "I have a big fuel rail".
Duane
NashMan
Aug 5, 2005
4,940
17
Victoria BC
thought about just runing it that way and run rabbit intake filter like that basicly a filter mesh cage
i useing bulk head fittind threading fpr on to my rail looks very clean look if i did it to stock 7m rail it whould crack form weight plus thought about tiwn feed and point less and look cluttered
keep em coming guys
Duane
Dec 3, 2003
6,653
Canada
Crack from weight? I didn't know that your fittings were that heavy! I must have very rare fittings as mine are not cracking my fuel rail!
I have -8 feed which I tapped in the OEM rail and is fine and more than enough for the power I have. Clean install too. The Lipp rail is not needed, seriously for your application. (unless again you just want to say you have it)
The pump is best mount IMO under car and low as possible. I have no pic as I am on work computer but it sits low and is good for better cooling and easy re & re.
Duane
NashMan
Aug 5, 2005
4,940
17
Victoria BC
my afpr is fitted on the rail no hose just one -10 fitting witch you can't do on stock rail it may crack if i had a hose on it be fine but i don't so this is why i have doen it this way
and i think i going to monte the fule pump on the bottom of the gas tank
but i gonna have to cheak on how low it's sits on my parts car
Duane
