what do i use for my stock rebuild 7M-GTE
a7d4fbird4sp
9
Manchester Nh
I have 2 7m-GTE blocks one is good other is not. 1 good crank 2 good sets of connecting rods 9 good std size pistons. I also have a complete non-turbo engine should i use the cams from the na motor? or use my stock cams i would like a little more power but would like to retain stock look outside. Car only has 87k on it and is mint. can i use the na block or should i stick with the turbo block i can see the diffrences on the outside but have not torn down the na motor yet was told poss hg issue
Fozbo
7M Love
Apr 4, 2005
290
Norman, Oklahoma
I'd use a 7MGTE block instead of a 7MGE block because the turbo block has oil squirters that spray the internals. I can't really say for sure, but there might be some things that aren't there on the NA block (like turbo oil feed outlet - don't know for sure).
a7d4fbird4sp
9
Manchester Nh
car had blown hg and was run for a while i guess melted pistons and dingleberries on head also cylinder walls pretty bad may be able to clean up ill bring it to a machine shop when i get a chance to see if it can be saved
why is it bad if you do not mind me asking?[/QUOTE]
