Reign_Maker said:wideband
supra90turbo said:Search the local vendor's online stores for Wideband O2 kits.
Reign_Maker said:Horsepowerfreaks sells them, MVP sells them, Titan sells them, 935motorsports sells them... Lots of companies sell widebands...
A wideband doesnt work with your ecu, a wideband works like an oxygen sensor, it reads the a/f ratio in your exhaust and gives you a read out... They sell A/F guages, however, that's what's considered a shortband, and its practically worthless... Its great for dancing lights, but not for a true reading...
The air fuel controller, like an SAFC, has nothing to do with a wideband...
hth...
Jake
Or narrowband....Reign Maker said:that's what's considered a shortband,
supra90turbo said:Or narrowband....oon:
Yea, sorry SimpleIcon, by "Local Vendors" I meant local to the board... I should have been more clear. Any of the vendors that Reign Maker mentioned is a good place to check.
Also, as mentioned, a wideband o2 simply monitors air/fuel ratio, and does not, in any way, work in conjunction with your ECU. Just have a bung welded in your downpipe before any cat's and watch how pig rich you run!
Good luck!
Dziuggy said:next tim mod will tell me chill i will tell them to go f**k them selves.
we have way to many noob ricers going around here lately.
go read about.com on how engine works then come here use search button and then ask the questions
my flaming comments shall be with held from both of you guys.SimpleIcon said:Hmm, that doesnt even deserve a comment. Any Moderator want to get rid of this getto-sounding troll?
Good luck!
