So, my #1 cylinders had a loud knocking coming from it. I know its #1 because I can hear it through the engine and when I pulled out the #1 sparkplug it became very noticeable.
The piston had no play sitting in the cylinder and there are no scars on the cylinder wall. I pulled the piston out to check the pins and bearings.
According to the Toyota tech I talked to you check wristpins by putting them halfway into the rod and wiggling them, no wiggle means ther fine. Did that and no wiggle, perfect fit.
I then checked the crank, no scars, still perfectly smooth.
Then too rod bearings (these are being reused from before the teardown).
They seem a little to arched, like they have to be bent slightly outward to fit onto the crank. Just slightly though. I dont know if thats how theyre supposed to be or what.
