What could it be?
supraguy@aol
Well-Known Member
Dec 30, 2005
4,239
Atlanta
Codes?
And your windshield has more crack goin on than downtown Detroit.
It scatters the light from your low coolant warning all over the place.
SupraTurbo_MK3
76
Amherst Ohio
Are you venting to the atmosphere?
That a/f meter won't be very accurate, in fact it's almost useless......You are much better off upgrading to a wideban sensor
memo226
5
Tucson, AZ
No tps has not been adjusted. Will do it tomorrow. Yes I have only a blitz and it vents to atmosphere but its never done this. And would a knock sensor do that?
_
supraguy@aol
Well-Known Member
Dec 30, 2005
4,239
Atlanta
Does it stumble and go rich if you rev it, but don't pop open the bov, or is it just after the bov vents?
If you vent a bov to the atmosphere, the metered air going into the engine(x) immediately after, was measured with that vented air(Y).
So the ecu supplied fuel for X+Y, when it's really only getting X, thus a very rich condition, and very well known from those who have used
atmospheric bov's on a stock air metering system. I can't tell you why you haven't seen this before.
