What could cause this??
mhopemk3
The CT install SPECIALIST
Jul 13, 2005
762
Jacksonville, FL 32277
Pulled the head this weekend due to (my thought of leaky valve stem seals). Car will puff on start anfter sitting a while and will puff when coming to a stop when normal driving. The puff is white smoke.. Anyways this is what I found. I did a compression check with these results. These were on 5 turnovers. I cranked it over about 8 times on a few and got up to 180.. I did warm the car up a little. Just let it idle a few minutes. Not norm operating temp though.
Why the oil in 6? Would leaky seals cause this?
1. 160
2. 170
3. 165
4. 165
5. 170
6. 165
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
Yes...leaky valve stems seals could cause that. If they are leaking the oil will run down the valve and onto the piston.
Why did you pull the head to change the seals...this can be done with the head on the engine?
sleepersupra
i hate this car
Nov 5, 2005
311
Broken Arrow, Ok
ok i'm glad you wrote this but since you said that it can be done on the car that means that i'll be ok and won't have to worry about my head or block or mhg since i just finished it?
mhopemk3
Jul 13, 2005
762
Combo of reasons.. Most because I am ready to upgrade Fuel, Injectors yada yada and turn up the boost a bit. So I really wanted to change the HG as well and torque it down.. I just bought this car a little over a year ago and wasn't sure of what had or hadn't been done to it..
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
sleepersupra said:
ok i'm gald you wrote this but since you said that it can be done on the car that means that i'll be ok and won't have to worry about my head or block or mhg since i just finished it?
I don't see why this would be a concern...If the MHG can handle the high pressures of a boosted engine then why would some oil in the cyclinder cause problems?
joefoe
17
It's a big problem becuase oil wil effectivly lower the oct rating of the gas. Lets say you run 91 oct but there is oil in the mix, you boost it pings like a mofo.
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
I'm not promoting running it like this...or saying its ok...but its not the end of the world as we know it...it needs to be fix. But oil its self is not going to make the HG leak or cause any damage just by its self.
SublimeSupra
Dreams of the Touge
Jan 17, 2006
170
Largo,Fl
Well actually it could as stated above.Oil and gas mix equals less octane less effective burn.That can lead to detonation under boost which blows HGs.
