Here's the deal, I got a 1j AT supra swap into my 89 AT. The problem is it will not run right with the original ecu. It will crank but when you move the ecu around it starts stumbling, running rough then cuts off. All plugs have a tight fit. I bought another auto ecu and it doesn't even crank but here's the crazy part; put a manual ecu in to try and it runs dam near perfect. The only thing we can think to do is go back and check the engine harness auto trans wires. 3 ecus and the one that not made for my swap works. Any ideas?
