What are these called?
Beatrice
Toyota Whore
Feb 5, 2008
100
Louisville, KY
This is one of the "mounts" that the radiator sits on. I believe they are called bushings, since they look like one but when I try to look up on autozone's or o'reily's websites for them it says they can't find the item.
jdub
Feb 10, 2006
10,730
Valley of the Sun
I believe it's called a lower radiator support, but can't confirm it. I'm pretty sure that's going to be a dealer only item.
Beatrice
Toyota Whore
Feb 5, 2008
100
Louisville, KY
dang, you wouldnt happen to have a part #, would you?
Beatrice
Toyota Whore
Feb 5, 2008
100
Louisville, KY
lewis15498;1358706 said:
Boneyard run!
lol well im trying to avoid that because I work through the week and the weekends are the days where the local yards are packed, or at least the decent ones.
Guyana00
Droppin that JZ in soon!
Apr 18, 2007
1,208
Brampton, ON
You're avoiding yards because they're packed? I would go to the dealer and get a price, doubt it would be much.
If not get up early saturday and head out, will pop out easy obviously and you're out.
rayall01
901
Westfield, ma
In a pinch, you can stuff a rag in the hole, and with a little creativity, you can make sit at the correct height. My stepson, somehow, lost one of his, and that's how we fixed it. (Cause he was too cheap to by the f-ing thing.)
jdub
Feb 10, 2006
10,730
Valley of the Sun
LOL...now that's cheap ;)
Keep something in mind about the radiator supports, they are made out of rubber for a reason and it's not shock isolation. If you get even a small electric current, the coolant acts as an electrolyte and turns the rad into a sacrificial anode.
supraguru05
Dec 16, 2005
737
louisville ky
ding ding ding
beatrice i can go get you one from a yard let me know
Beatrice
Toyota Whore
Feb 5, 2008
100
Louisville, KY
supraguru05;1358966 said:
ding ding ding
Im assuming this is kyle lol. Yea, if you could or if you have one laying around. Just pm me on here or 502 and let me know how much
supraguru05
Dec 16, 2005
737
louisville ky
i dont have one and pullapart doesnt have any either i just checked. although they have two cressidas and they might be the same.
Beatrice
Toyota Whore
Feb 5, 2008
100
Louisville, KY
jdub;1359349 said:
There is a wonderful communication device that's available: The Telephone!
lol i know but this is an internet age. Plus its more convenient to just order on line, at my own leisure.
rayall01
901
Westfield, ma
Just so you know, it was a plastic capped radiator, so using the rag posed no issues. (Except for aesthetics).
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
arent all mkiii ones plastic capped?
so rubber when you are making your own rad supports?
jdub
Feb 10, 2006
10,730
Valley of the Sun
A lot of aftermarket stock rads have plastic tanks...OEM is metal.
Rubber needs to be between the support and the car's frame to prevent grounding....through bolts on the support to the rad will provide a ground path.
