What and where does this plug go and do?
xzeror
1,356
Miramar, FL
kotu100
1,899
Easton, Ma
Trace the wire and see where it goes. U can use the tsrm as well. I don't think it's a Toyota factory wire.
xzeror
1,356
Miramar, FL
its connected to the yellow plug in the first pic and goes to the wire loom i think its called ( the plastic thing behind the cover that says 7mge with wires in it) and i cant follow it after that
mkiiichip
1,434
WI
that is not a stock wire, if you want to know what it does you'll have to do a little research (under your hood)
1. open up the loom and see what wire it goes to,
2. the connection inside the loom: Is the factory wire taped into, or cut and extended (replaced) with the solid yellow wire
its hard to tell in the pic. Is there one wire that exits the loom, then a couple of loops with a wire tap at the end?
more info is needed.
