how are you guys doing. my names jay im the proud owner of a 1989 supra turbo. 120000 miles on it pretty much near mint condition. i need help filling in some blanks on a parts list i figuered you guys could help me out. keep in mind my goal is to be in the 400-500whp range and just have a reliable ride.
(the parts listis as follows that i own as of now)
JE Forged Piston set. .020 Over 8.5:1 JE Piston set with Hastings Rings. Clevite77 Rod and Main bearings and Thrust Washers
Full Engine Gasket set with TEP Metal Mix head gasket
ARP Head Studs, ARP Rod Bolts
24 Stainless Steel Valves
Timing Belt
Tensioner
Water Pump
GReddy Boost Cut Controller
Apexi AVC-R boost controller
Apex-i Neo fuel controller
Aeromotive -6 FPR w/ stainless steel fuel lines and fittings
Fuel Pressure Gauge
550cc Injectors (6 each) w/ Injector Clips
255lph Walbro Fuel pump
High flow cat
Blitz NUR Spec Exhuast
3in TestPipe
TMS 3in Downpipe
As of rite now thats all i have purchased and its staring at me. im looking for the best cam gears to reach this ,goal turbo systems and anything that should be replaced on the list. thank you for the help and hopefully ill have pics of a build in the build up section once the other parts i figure out.
Timing Belt
Tensioner
Water Pump
Fuel Pressure Gauge
High flow cat
3in TestPipe
TMS 3in Downpipe
