west canadian mkiv
jamesthejames
Canada
hey all, thought i would give this forum a try, been a member of supraforums for a while now./
About me:
Living in campbell river, on vancouver island
My car is a black jdm 93 mkiv hardtop
When i first got the car it was bone stock, which i pushed to the max, ended up dynoing 367 RWHP at PacNW meet at forcefed with the stock twins.
Finally got bored of that, so tore it apart this winter
Finally got most of my parts to start putting together, my goal it to have it done by the end of may.
did a compression test and motor is within 5psi of perfect so decided not to pull the head, will run the original internals till something happens.
Parts include:
HKS GT2835 twin turbo kit
950cc FIC -8an kit
Tomei FPR
triple denso pumps (might only use 2)
carbonetics triple carbon clutch
mishimoto rad
electric water pump and rad fans
160amp alternator
Power Enterprise timing belt
Titan harmonic balancer
SP billet timing belt tensioner bracket
262 BC cams
manley springs/retainers
Oem valve stem seals
Oem gaskets where needed
Snow Methanol injection
MSD blaster ss coils
USDM brakes
BC coil overs
adustable upper control arms front and back
not purchased yet, but am going with a microtech ecu system from marco at forcefed.
my goal is 650RWHP
Will post pics in a few days.
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
Welcome to SM, jamesthejames! (I can only assume your name is James)
Don't be afraid to post more pictures - After all, this is just a "toy" car forum for adults, right? We all like photo's. :)
And 650RWHP should be no issues as long as you've got a healthy, reasonable tune - What are you planning to use?
