werid nosie when i turn left
MK3Racer89
146
well it started a couple of days ago, it is the front right wheel, it only makes a nosie when i turn left and it sounds like the strut of the wheel bearing but i dont know, i took the tire off tire too see if i can see anything wrong or anything missing but everything looked normal. sooooo....... i am stumped on what is making the noise and i am hoping it is not the wheel bearing because i heard that it is hard to fix. so any help would be great thankz guys
chris
MK3Racer89
146
haha yeah but i am going to have my friend who works on toyotas look at it when he has time but i wanted to find out the general problem
MK3Racer89
146
it sounds kinda like something making a deep/loud knonking and it kinda sweaks/scrapping sound too and it sounds like it makes the sound at the same spot each time the tire rolls. hope this helps i will try to think of anymore stuff to narrow it down.
CSquared
Atlanta, GA
Is the sound when you have the wheel turned to full lock? If so, you should be ok. My car does the same thing and has been doing it since day 1... usually just on really tight turns or u-turns. I'll qoute someone else so you can't blame me if I'm wrong.
As per drjonez: "if you have noise @ full lock it is the plastic cap (or lack thereof) on the wheel stops. go buy it from the dealer for $1, cover it and the strike plate in grease and drive happy."
Jonez knows his stuff.
MK3Racer89
146
no not at full lock on really wide turns it does not do it sometimes but on normal turns it will
MK3Racer89
146
do you guys think it is the strut ? how would i know the difference from a wheel bearing and a strut that has gone out ? besides taking it apart and if it is a wheel bearing is it hard to fix?
MK3Racer89
146
where is the wheel bearing ? i think i know but i am not sure so i was wondering if anyone could let me know, thankz guys
chris
CPT Furious
Now MAJ FURY!
KDOV
I had a similar knocking noise on mine and it turned out that the sway bar end link had not been re-attached appropriately. Whooops...
