Welding Rear Subframe
garagefujimoto
Local Tire Destroyer
May 27, 2005
997
Calgary, Alberta, Canada
Other than the area around the front diff nose, any other areas that should be welded up for durability?
Mine isn't cracked yet, but I'm setting it up to have it ass kicked in the future without cracking.
If anyone had pics that would be sweet/
lintlars
ROOTS RADICALS
Ft.St.John BC
Heres a shot of mine a laminated the nose part and put gussets on the main large opening and put cross bars on it I also stitch welded all existing partial welds I also filled the six rubber mounts with windshield glue while you are at it weld the backs of the camber/caster adjustment backings they tend to bend out
mp51998
25
Corpus Christi Texas
What are you guys using to cover them after welding? Are you just painting or powdercoating or anything else special? I have removed mine but wasnt going to weld anything because there were no cracks. I guess I will be adding the support that were mentioned in this thread.
Mike
