Typically I'm pretty good at figuring out wiring. But this has me launching random sockets across my garage. my Windows, seat, and heater control don't work. I can jumper the power main relay and get my Windows and seat to work. That led me to believe the relay was bad. Tested out fine, checked the other two pins, and discovered both sides had a 12v. Which is also the issue at the heater panel, the ground location is showing 12v. Makes sense because they both eventually tie into the ground that terminates at the drivers kick panel set bolt. There is no power making it to the ground. So by the tsrm I need to find j/b number 7.
Unless I'm missing something obvious.
what i know:
the power main relay should have 12v on pin 1 (lower) and ground on pin 3, however i have 12v to both plugs
if i jumper 2 and 4 i get my power windows and side/lumbar control
2 climate control units DO NOT work, both tested fine in another car.
all my Circuit Breakers are good, none are setting off, all fuses replaced with brand new fuses of the proper size.
the odd thing is, it was all fine one evening, then the next morning nothing worked.
what i know:
