I have been having all types of timing issues with my motor ever since I put it in this car. I decided I am going to fix it all this time or not drive it any more. I have searched quite a bit as I have never completely done the timing on a motor, even though I have played with all of these parts enough to feel confident with the help of SM.
Well, I have tried several different methods with no luck. What I have does not look right at all. I have everything as right as I think I can get it, but look at my cam gears. I tried it a couple of times while having a brain fart, and thinking the cam lobe was showing TDC. That was due to the lower pic on this page:
http://cygnusx1.net/Supra/Library/TSRM/MK3/IG/IG_021.gif
I tried aligning the CPS both with the cam gears on the marks, or with the cam lobe in the up position. I do think I was not on the right stroke when I did that, so I pulled it all back apart, and started over. Now I have the #1 piston at TDC, the cam lobe up, both gears with dowels in the center holes (they weren't before) both on the gears and the cams, Crank Dampner at 0, the CPS installed, and aligned with the rotor right on the sensor. The only problem is the gears are at about 2 o'clock. My question is, do I just straighten them up and not worry about the cam lobe? Or is something wrong here?
Here's the best pictures I could get.
I want to just go straighten them to the marks, and put the timing belt back on it. But, I'd much rather have a little back up before I mess all of everything else back up.
Here's one more pic of what I found when I finally pulled the plug out of #1. I'm assuming that's a timing issue. Could it have done any damage? I read during my search that this was a non interference motor, meaning that it was impossible for the piton and valves to come into contact.
