weird oil line on dipstick
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
Ok today after i went to go do some stuff I parked the Supra in the garage and checked the oil. I lifted it out cleaned it off and put it back in, waited a few seconds then took it out again. Oil is solid til the half full mark about then there is oil only on half of the side with the grid. Is it full of oil or is half full?
BoostnLoose
114
Canada
more then likely only half full, wait alittle longer and try again.. it might just be rubbing on the side of the rod when you lift the stick out
koulee
497
Thats why you take multiple readings. Solid across is what you are looking for. The auto tranny dipstick does this as well.
