Weird Code 31:
SC2JZ300
13
Atl
Problem started the other day when I was coming home, driving normally, and my car throws a CEL, car starts to hesitate, car wouldnt idle correctly at stop lights, and eventually dies, ETC.
Came home and did a diagnostics test, and got one code, code 31 < Bad AFM... Did a resistance test to confirm and Replaced with a used one, did a resistance test to make sure the new one worked.
Installed the newer AFM and did a RESET and got the car to idle correctly, but when in gear and driving the car seems to bogs/Hesistate at low RPMS then drives fine in the upper RPMs.
CEL continues to come on inconsistently... Sometimes for a few minutes, goes away and comes one again....
Im not sure if it is still the AFM, but Diagnostic code CONTINUES shows Code 31 which is AFM unit.... Not really sure now....
Help Please
