Well, I've had 3 different turbo's on my car. The first, which was a .57 Trim, I bought it with it on there, and not until the last few months that I had it on there did I notice that I would get what I think would be called "boost spike". From searching, I've found that boost spike usually occurs by the MBC all depending on a spring that will sometimes spike up the boost instantly. I have no boost controller...However, After putting a stock turbo back onto my car...It still did the same thing...
"80% of the time, if I went WOT from a roll, after about 3-5 seconds of being WOT, my boost would be at 11psi or so...then within a split second, it "spikes" to 15, hits fuel cut, and then I back off. I thought it was the turbo itself...so after installing my 60-1 CT26 tonight...Going on a test run, I've found that (driving at a normal 9psi)...it will spike up to 15...AGAIN.
I thought it was the turbo/wastegate causing the problem...so what could it be. I am stumped. I thought it could possibly be my AFM which has been through hell and back because my filter sits under my headlight and it's seen some very wet days...:icon_conf
