Hey guys I acquired this ecu from Jag to use and when I went to plug it into my harness I came to discover it had two plugs that don’t look like they go to anything.
On the top side of the ecu it says A/T which means the ecu is made for an automatic but it was used in a 5spd car also I have never seen an automatic ecu like this, Mind you I have a 5spd wiring harness in my car from a JZA70 has anybody ever ran into an ecu like this before?
What are your thoughts on this any idea how to make it work with my harness or should I keep searching for a 5spd ecu?
