weight!
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
if you guys had to guess how much would you say my car weighs? after removing the whole a/c system, all the ps, all of the crap you dont really need under the hood. all of the sound deadining under the carpet, and the complete heating system? i think i weighed the ac stuff and it was around 35lbs, the sound deadining was 36lbs the heating stuff was 26lbs and the ps was about 5-10lbs. alll together about 100lbs not to mention the weight diff in the motor the 1g compared to the 7m. i know the 1g is alot lighter cuz my front end is really high off the ground and there is like a 6-8in. gap between the tires and the fender. just a random thought thats all.:naughty:
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
here is one from when i first got the car kinda crappy but you can see the huge gap. it steers weird with it this high also.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
Meh, this is like "how much horsepower do I have with intake, exhaust, dp and 10psi?"
Just weigh it. It's free!!!!!!!
shaeff
Kurt is FTMFW x2!!!!
11
Around
Supra Sound said:
Model No. Curb Weight
2386 3561 lb.
2387 3645 lb.
2388 3535 lb.
2389 3621 lb.
2395 3550 lb.
2396 3517 lb.
2397 3601 lb.
2398 3464 lb.
Heres the model numbers
3-Door L/B Turbo 4-speed Automatic MA71L 2386
3-Door L/B Turbo w/Sprtrf 4-speed Automatic MA71N 2387
3-Door L/B Turbo 5-speed Manual MA71L 2388
3-Door L/B Turbo w/Sprtrf 5-speed Manual MA71N 2389
3-Door L/B w/Sprtrf 5-speed Manual MA70N 2395
3-Door L/B 4-speed Automatic MA70L 2396
3-Door L/B w/Sprtrf 4-speed Automatic MA70N 2397
3-Door L/B 5-speed Manual MA70L 2398
that has the stock weights of your car.
and here's the A70 weight index, thanks very much to sammydafish.
http://www.trdsupra.com/
so, start by finding out what your car weighs stock, then go to the weight index, and subtract the weights of what you've removed, and make sure to take into account the weight difference between the 1g and the 7m. :) and i'm sure you'll find the approximate weight of your car.
-shaeff
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
ok i guess im dumb... where do you find the model number on the car? i know its a ma70L and it was an auto. so im guessing it weighs 3517 right? stock that is. so it would weigh around 3331lbs not counting the wieght diff. in the engine.
