A gear dependent boost controller. low boost for the first couple of gears then high boost for the last gears. progressive boost as we row the gears. who can make this happen? i bet we could get a group buy.
tissimo;1139306 said:I bet 98% of the cars on this board do not need this. If you're spinning the tires sub 450whp in 1st and 2nd gear get better tires. When you're making that much power a standalone is a good idea and some have boost control based on that built in (VS speed or gear)
supraguru05;1139316 said:heh i have a hard enough time keeping the rear tires from spining on stock boost with 275s. just try turning and putting power down. however this would not help me since im only in 2nd gear anyway for autocross and I dont have wheel spin issues on road courses
I run a 4.30 rear-end in my Supra, making close to 500whp. There aren't a lot of other tire options for me other than full-on drag slicks.tissimo;1139306 said:If you're spinning the tires sub 450whp in 1st and 2nd gear get better tires.
