Ways to Clean Up stock exhaust Manifold/Places to Buy NEW?
Turbo Habanero
4,229
Tucson,AZ
So i just put my order in for one of Alberts Billet 58trim CT-26 rebuilds and just wanted to be able to make my Exhaust Manifold look Cleaner/Pretty for the new turbo.
Is there a replacement CT-26 Exhaust Manifold ?
Whats the best way to go about cleaning the stock one and can i paint it with high temp paint?
Thanks for any idea's in Advance
-Jordan
Greek
513
Ohio
I did this with a bead blaster. It took a while to get to the bare manifold, but it looked really nice. You can use high temp paint afterwards if you want.
Greek
513
Ohio
If you blast it, take care what type of material you are using. Some will get embedded into the manifold and come out later, which will get into your oil system. The material I used was good sized and I still gave it a thorough air blasting afterwards.
Compton74
355
Long Beach
high temp paint works wonder, made a night and day difference on the look of my car. Also clean up the heat shields and paint them up as well.
mkiii222
Troy, MI
+1
I used a wire wheel on mine when I did my HG job. Got rid of all the rust and makes it nice and shiny again (I used the 'silver' color).
Jay C
283
Omaha, NE
the Swain "white lightning" coating looks like it might be good. I dont personally dig the white but thats just me.
Van
87t Hardtop
Mar 26, 2006
974
Oak Grove, OR 97267
Or, after you blast the rust off, get it ceramic coated inside and out, so the heat stays inside the manifold, spools up the turbine nicely, and can be chrome look or like mine, flat black. Flat black is good to 1400 degrees. Van
