Waterpump
H-Dogg
125
Watertown, Wisconsin
This is my waterpump!
And I kinda figured I needed a new one because of me being me while pulling it off! But I found this on ebay and was wondering if it was a good idea!
http://cgi.ebay.com/ebaymotors/93-98-TOYOTA-SUPRA-TURBO-2JZ-GTE-WATER-PUMP-WPT-038-NR_W0QQcmdZViewItemQQcategoryZ33604QQihZ011QQitemZ320132545162QQrdZ1
Ric
Setting the standard
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
Dude if you want a used non hydrofan front, $15 will get you a 30k mile OEM 1JZGTE Soarer pump (same as mkiv 2jzgte in the link) on your front door from me.
Or you can just go buy a new one for $46
mabru
part-time
Apr 5, 2007
27
Okinawa JP
I don't think that was pulled from a 2J turbo motor. The ones I've seen have a metal impeller not plastic. Soarer 1JZ pumps were clutch fan and had plastic impellers.
1jzMoe
263
Vilseck, Germany, Germany
you can buy a 2jz water pump and either use electric fans or clutch fan, direct conversion. No fabricating, just make sure to get the upper and lower part of the water pump. I am using that on my 1j alone with electric fans and haven't had any problems as yet. I would also recommend changing your timing belt as you are in there and checking the whole timing belt tensioner, or if you want the hydro fans you can get a new water pump from champion toyota, thats the only place i know of that sells stock 1jz parts from the manufacturer, if you have any questions pm me.
