how likely is the water temp sensor my problem?
First time cranking it, it has to crank several times to fire up.
on cold start it idles fine, close to 1000, for warm up.
after it warms up, idle fluctuates between what looks to be 500-550rpm
I've set tps, timing. checked isc, egr, plugs and wires, all vacuum lines - good
Water temp sensor has a crack around it and it wiggles. I don't, however, have code 22.
