water sucks....
suprasick
Hey look...a Supra!
Mar 17, 2006
291
Milton, Washington
So here in washington it kinda likes to flash flood... so last night the roads were kinda flooded and i had to get home. When I was driving the main road ahead of me looked like it had maybe 6in of standing water... well i was wrong, there was about 2 feet and the supra took on some water especially into the intake (ram air unprotected).
When i was going through it i was doing what anybody else would do when 2 feet of water was around you... screamin "oh shit" ... so mental note dont pull a dumb ass move like i did and try to guess a flooded roads depth....
So i took my hydrolocked supra to my local performance shop and he said that my engine was toast... its a non turbo and this is going to be my second motor swap but this time i wanted to go turbo just gte engine, wire harness and turbo ecu right? thanks
It's got to be easier than the 1jz swap, so I would say it's well worth the time and effort it will take you. You can do a search on here and find all of the answers you need..............lol
mkiiSupraMan18
Needs a new username...
United States
If you get the harness/ecu, it'll be just like putting the NA engine back in... but with a little extra weight on the exhaust side. :icon_bigg
If you need help, feel free to PM me, done it a few times.
Your tach wont work... thats the biggest PITA.
If the tach is the only thing he's got to worry about then he's got it made.
What's up Matt?
mkiiSupraMan18
United States
^ same ole shizzle. Just out being my normal non-arsehole self. :icon_bigg
Seriosuly though, swapping 7mgte into an NA chasis is a BREEZE. Hell, I've done it twice. Thats saying a lot. :icon_bigg
supramacist
1,501
The Grassy Knole
why not just put a v8 in it. This is being done with the 305 gm block. I have driven turbo charged 4 cylinders and ya they run fine. But I would rather go with the 7mge than the 1jz. But that is just my preferrance.
mkiiSupraMan18
United States
^ I'd go 350 if I was doing all the effort. You can rebuild that mo-fo for next to nothing too! $300 would get you brand new everything just about.
suprasick
Hey look...a Supra!
Mar 17, 2006
291
Milton, Washington
yea they tried to pull the plugs and manually crank the water out and still it wouldnt turn and he also said that the timing belt was stripped of some notches
mattsplat72
is sofa king
Jan 17, 2006
1,738
Hey suprasick give me a call my name is matt 425 244 8575 I live in Mt Vernon .I just had a ge to gte swap done in August . One of the guys here has a shop in Vancover Wa and they did it was about 2500 for the whole thing . Wiring harness,Ecu,Motor,down pipe fuel pump ,and clutch. They ran into a few issues with minebut after my swap they have those problems figured out . Really nice guys and easy to work with . Did a fantastic job on the swap .It looks perfect other then the fact that I am debadged you cannot tell that it is a swap
