water pump
AZN MK3
341
Now in the U.S.
ok this thing is racking my nerves... when changing out the waterpump from a hydro fan set up to a mechanical set up is the housing the same or do have to change that out too??? because i've searched and searched and i see that i have to change it if i dont want the hydro fan thingy set up to the mechanical one.... well im just wondering if its gonna be bolt bolt bolt... thanks
aphxero
787
Seattle, WA
You need the whole thing. Bolts right up. 2jz turbo pump assy from dealer is a pretty good price.
AZN MK3
341
Now in the U.S.
do you have pics... it'll be a whole lot easier for me to figure it out through a pic.... if its fine that'll be really nice... thanks
Adrian98
182
orange county
there's like 4 water lines in this.
one up (hard pipe)
one back (bolt on hard pipe)
one out the side and back where the thermostat goes
and a clapped hose on the side.
AZN MK3
341
Now in the U.S.
one up (hard pipe)
hey thanks man... really appreciate it... so the housing has to come with it, like this???
AZN MK3
341
Now in the U.S.
ok ok... i've been goin at this in my head now for quiet a while... because my water pump housing looks just like that in the picture... absolutely nothing is different... unless theres something there that i cant see... but im just wondering why again do i have to get the whole assembly including the housing that the water pump goes into???? i honestly dont see anything different at all with the one i have... really would appreciate any input...
tsuper92
supra addict
Apr 7, 2005
1,376
mass
the regular 2jz waterpump will not match up with the hydro fan housing.go to your dealer and ask for part#16100-49846
jz*supra
164
Lethbridge, Alberta
Sorry to sort of jack your thread but this is a concern you may also have. Does the 2j pulley line up with the 1j belt? I just my 2j pump on, and the bolts for the pulley are way out of line.
zoomin.php
Does the 2j pulley offset and go over the pump so it lines up?
AZN MK3
341
Now in the U.S.
zoomin.php
i believe it does... i got the pulley and all but i didnt buy the water pump yet... did you change out your housing???
jz*supra
164
Lethbridge, Alberta
Yes. It is a complete toyota 2jz pump and rear assembly. I dont think the 1j housin can be used with the 2j pump. I bought the 935 "conversion kit" i really doubt they would sell the whole pump and rear assembly inless u need it.
AZN MK3
341
Now in the U.S.
does it matter if its an n/a water pump or not???
935motorsports
San Diego, CA
Yes you need the 2J water pump and housing, along with the 2J pulley (cheap on ebay).
The water pump setup comes with gaskets if you order it from the dealer.
The pulley is offset, which is why it seems like the bolts don't line up.
AZN MK3
341
Now in the U.S.
ok but will any 2jz water pump work meaning... n/a or turbo does it matter???
tsuper92
supra addict
Apr 7, 2005
1,376
mass
you need the turbo one for the coolant line for the number one turbo.the n/a most likely doesn't have it.are you looking to buy used?i have a low mileage one with a pulley.
csnow
Matthew 6:33
Palm Bay, FL
I am putting a hydro fan together now. I have the waterpump and clutch fan if you need it. PM for details. If you have the hydro parts I am missing, we can work a trade.
