supra90turbo said:
Paging Mr. Scott Henessey
look up hottscenessey (i think thats how it's spelled)
LOL, yes I'd definately say that meth injection is one of my favorite mods. I ran it on the 7M, as did Mike (Malloynx).
I ran a 14GPH nozzle, which allowed me to take out about 20% of my fuel w/ 550cc injectors, and an SP61GT at 21PSI. The fuel was taken out using the "trigger" setup on the MAF-T. Very simple setup. This was using a kit from devilsownonline.com
For my next setup I'll be using the same kit on my 2JZGE, but I'll be using dual 14GPH nozzles since usually people are pulling around 25% of fuel.
One thing to note.. alochol injection must be tuned (I used my WBO2). It will definately clean your internals.. I noticed smoking after a few months of running the shit out of my car. I think it was from cleaning the old engine of carbon deposits which helped my piston rings seal.. causing some smoke.. still I had perfect compression across the board. (Just speculation.. I also had a dead turbo.)
The meth I used was walmart's windshield washer fluid (the WINTER mix). It's roughly 40% meth 59% water (good combination). The rest is just detergent and blue dye which can't hurt! I know it works.. because I spiked to 26PSI one night when I was not tuned, and there were no signs of detonation.
