I fixed the water pump, and went for a test drive she started overheeting pretty good, so I got it home. No when I put water into the radiator it sounds like it's taking a pi ss. I put more water into it and crawled under it and it looks like the water is leaking from the circular peice the turns the fan? Would this be that I have blown the main front seal? Or a head gasket?? I'm not sure of wich end is up but all the work i did on the power steering fluid looks good but it's making those whinning and moaning noise again. What has happened here. Any comments would be appreciated, even the bad ones since I figure nothing good can come from this, thanks, mike
