wastegate upgrades?
boost fiend
852
Rockford, Il
so does anyone out there know of a upgrade to the ct26 wastegate actuator? i have mine shimmed, but i think i would like to get my hands on a lil better one.
souprat
fairfax VA
never heard of an upgrade for the stock wastegate. i dont think you would really need one if people can run 20+ psi on an upgraded ct with the stock wastegate. maybe i am wrong??
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
i bought a dual port actuator from HPF. I had to custom fit it with fabricated mount. It lets me add pressure to the backside of the diaphram to increase boost pressure with an air regulator.. works great but boost will creep up if its like 35 degrees or colder out.. i dont know if anyone else runs a setup like me on here. :dunno:
boost fiend
852
Rockford, Il
ok. looks like i keep searching. im getting a 60 trim upgraded ct and just thought that a better actuator might be a good idea. is there a spring or anything that i can get to make sure i can keep and hold boost? i know prob a stuipd question, and im wearing it out.
