Wastegate spring Q's
sao1
104
Santa Rosa, CA
Hey everyone,
I need clarification on the spring i have on my Tial 38mm wastegate.
I have a the wastegate with a 7psi spring, what does that mean?
Does that mean, the wastegate starts to control AFTER 7psi? Or does it mean that it can only control UP to 7psi?
Thanks in advance. :)
sao1
104
Santa Rosa, CA
I have a boost controller and boost cut on my standalone set at 18psi, will my 7psi wastegate spring able to control it?
I
itr206
Guest
it means unless you have a boost controller, the Wastegate will open at 7PSi and start bleeding off pressure so you cannot make more boost.
