Pretty much, i'm having issues w/ creep and when my wastegate is opening.
-it CAN open as soon as 1 psi, sometimes i can hear it opening before my stock boost gauge even activates (so it'd be in vacuum)
-when it opens, the turbo keeps on spooling, it slows a good bit once it gets to about 10-11 psi, but it will hit spark/fuel (whichever you choose to call it) cut in 1st and 3rd (if the turbo is hot enough) and 4th for sure (under any operating temp)
this is on a stock ct-26 w/ stock wastegate, no boost controller or shims on the solenoid
Should i go ahead and replace it? Can i get one from toyota? Or is there anything else that could be causing this problem?
also note that i can hear when the wastegate opens because of the bic ddp
