wastegate/compressor question
Back2Basics
Regular
Dec 30, 2005
317
Milwaukee, WI
the guy before me had a mbc in there and i took it out because it was a really poorly made one and most likely leaked. can i just have a hose connecting the wastegate to the compressor housing nipple like how the mbc is set up?? if not where do i connect each hose and will this get me to the stock 6.5 psi. and if no for that as well how do i get back to stock psi for the time being? thanks
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
it will put it back to stock. The stock psi of 6.5 is not just controled by the wastegate. The wastegate is actually around 9psi of so. Other restrictions in the exhaust and IC piping cut this back to around 6.5, but again yes this will bring it back to stock.
