Wastegate arm hits Downpipe flange
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
So today i was working on my car, i unbolted the WG and after unbolting it i noticed that that the WG arm hits the Downpipe Flange. I believe its a Megan downpipe (starts as 2.5" ends 3"). Well the WG arm hits the DP flange causing it to not fully open. Im running a stock turbo elbow BTW.
Has anyone ever ran into this problem? Is it something to worry about? Thanks
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
Wastegates are for sissies anyway...
On topic though:
I've heard about this problem before with these DP's.
IIRC people were grinding reliefs in the flange to clear.
Are you have boost spikes?
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
On topic though:
I was hitting Fuel Cut at 12 psi, but I removed some shims from the wastegate and now its good, just under fuel cut at around 11 psi.
On mine it seems that the arm is actually hitting the DP Flange, seems to be to thick.
grimreaper
2,180
Dallas
I thought the wastegate opened into the elbow only? any pics? other wise grinf a groove in the dp so the flange can open fully (although it should limit boost as soon as it begins to open)
dumbo
1,911
Albera, Too Far North
Identical thing happened to me on my first freeway run, ebay downpipe. hit 15psi, good way to break in a new turbo haha. Just pull it off and bust out the die grinder.
