a while ago there was talk of someone manufacturing and selling PnP harnesses and Megasquirt boxes for a MKIII 1j. i was wondering if anyone heard anything else about this, and if they ended up making the PnP harness and the box with a base tune.
suprahero said:Would you care to elaborate Mr. XJ220.................Could it be you doing this.......:biglaugh:
foreverpsycotic said:would eather of them be able to use a distributer, or would i need to use a CPS
foreverpsycotic said:i was thinking along the lines of a 2jzge-t, using the 1jzgte harness. im guessing that it would need a cps and the 1j/2j electronics.
edit
or
would you be able to make a harness to put a 2jz-ge into a ma70
RacerXJ220 said:The thing with the megasquirt, is it depends on what you want to run, engine component specific. Meaning you have to buy the right megasquirt, with the right options (pre-built, or build it yourself) to work with the CPS, 36-1 trigger wheel, whatever.
This is why it's more of a challenge.
Certain megasquirt units do have knock control, and 2-step/traction control, as well as other features, but the unit, and the harness from the unit to the engine need to be in one place, at one time.
The 2JZ-GE block does not have the 12 point wheel on the crank, or the cam sensors. CPS, stock distro, or custom wheel on the crank are the ONLY options, meaning the 1JZ-GTE harness is a no go.
The 2JZ-GE harness is good enough, and the best option, and a CHEAPER option.
The 12 point sensor on the crank in a 1JZ, I thought about having a custom 36-1 wheel made to replace the 12 point wheel, and use the stock VR sensor. Now that would be nice. The Ford EDIS-6 setup is so easy to use in a waste spark setup.
