Warped inner timing cover?
Status
Not open for further replies.
Boostedmkiii91
14
Wisconsin
So i have a leak from the lower front region of the engine. Its not cam seals or from the hg or any oil lines anything of that sort. It almost seems as it its seaping from behind the lower inner timing case....Has anyone had that problem before? My other thought was also the seal behind the crankshaft timing gear i dissasembled the timing assembly and tryd to reseat it but to no luck with the leak. Any ideas?
If the front main is leaking then it needs to be replace.
Cannot take off the rear timing cover without pulling the head off. But yes it can leak oil.
Id clean everything off good and then look for the leak.
Status
